Well, I'm thinking about swapping out the flywheel down the road and am wondering...would a lightweight flywheel throw off the balance of the crank? If I remember correctly, the LT1 is externally balanced, right? Thanks in advance.
Lightweight flywheel
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Tags: None
Any takers on this one?Steve
Mods
Mods
Mods
There is a spec to the balance of a LT1 flywheel. (It is externally balanced) I think it is 95 grams at something like 72 degrees off of TDC. Don't quote me on that. Anyway if the flywheel is made to the specs required for a LT1 then it should be OK.Originally posted by Steve93ZWell, I'm thinking about swapping out the flywheel down the road and am wondering...would a lightweight flywheel throw off the balance of the crank? If I remember correctly, the LT1 is externally balanced, right? Thanks in advance.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
So, if I end up going to a Spec 2 or 2+ clutch with lightweight flywheel for the LT1, I won't have to worry about the crank being off balance, right? Since its for the LT1, in theory, it should have the spec-ed weight at necessary position you mentioned (95g at 72 deg. from TDC), and the weight reduction is all in the rest of the flywheel itself, right? Thanks for your help Jeff.Originally posted by Jeff 95 Z28There is a spec to the balance of a LT1 flywheel. (It is externally balanced) I think it is 95 grams at something like 72 degrees off of TDC. Don't quote me on that. Anyway if the flywheel is made to the specs required for a LT1 then it should be OK.Steve
Mods
Mods
Mods
Your choice of clutches doesn't matter when choosing the flywheel in regards to weight. The clutch disc and pressure plate are balanced to zero. My neighbor balanced mine with the clutch and pressure plate and match marked them to be sure but in theory it shouldn't matter.Originally posted by Steve93ZSo, if I end up going to a Spec 2 or 2+ clutch with lightweight flywheel for the LT1, I won't have to worry about the crank being off balance, right? Since its for the LT1, in theory, it should have the spec-ed weight at necessary position you mentioned (95g at 72 deg. from TDC), and the weight reduction is all in the rest of the flywheel itself, right? Thanks for your help Jeff.
Like I said, if the flywheel is made for the LT1, it shouldn't matter.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Oh I know the clutch won't matter, I was just using that as a hypothetical situation. At any rate, thanks for the help JeffOriginally posted by Jeff 95 Z28Your choice of clutches doesn't matter when choosing the flywheel in regards to weight. The clutch disc and pressure plate are balanced to zero. My neighbor balanced mine with the clutch and pressure plate and match marked them to be sure but in theory it shouldn't matter.
. Now I won't be so hesitant to buy one.
Steve
Mods
Mods
Mods
any1 kno the spec on the 400 sbc? and i think i kno the answer but i better ask anyways, would the LT1 flywheel work on a 400 sbc? thanks2009 Honda Civic EX- the daily beater
THe 400 sbc needs a specific weighted flywheel. It also requires a specific weighted harmonic ballancer, as it is externaly balanced. You can use a regular pre 86 flywheel on it with an aftermarket weight.Originally posted by 88bird5spdany1 kno the spec on the 400 sbc? and i think i kno the answer but i better ask anyways, would the LT1 flywheel work on a 400 sbc? thanks
Balance plate
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
