Well I've just fitted a strut brace, and I cant believe the difference its made. Cornering feels much tighter and more positive. the car doesnt seem to "dip" in turns like it used to. It also seems to turn in quicker. Easily the best mod I've made yet! $60! well worth it! Only trouble is had to bend Aircon pipes, Aircon refill point is touching bar, and the throttle cables only have 5mm room! I'll check in a weak to see if there are any signes of damage to the cables but all should be good!
I had 4 Adults in my car the other day, full tank of gas, and my Audio stuff in trunk (3amps and base box)... Any bumps or tight turns the rear suspension would bottom out or grind was hured under the wheel wells
I've looked for signes of damage,
seen
But whats caused this? Is it the dampers? weak springs? Is the suspension just aged (12 years old) Or was the car just over loaded?
I wanted to lower and up rate the suspension anyway, but its bottoming out the height its at now
Any ideas greatfully accepted!
cheers Phill
cheers Phill
