T5 borg and Warner 5 speed Transmission
  • T5 borg and Warner 5 speed Transmission
    Where can i purchase a new T5 borg and Warner 5 speed Transmission? thanks
    u might be able to get it from GM otherwise i dont kno where else? whats it for? if its for a 3rd/4th gen f-body drop a t-56 tranny in, they are much better then a t-5
      I don't think the T5 is made anymore. Tremmec bought Borg Warner's transmission division several years ago and I think the Tremmec 3550 replaced it. I'm not sure which model number would replace the T5. You might find that infomation here. http://www.5speedtransmission.com/ Your other choice is rebuilding your used one or buying a used one and having it rebuilt.
      Here are some used ones.
      http://www.tacreationsusa.com/manual_trans.htm
      More info here,
      http://www.ddperformance.com/3550tko5spd.htm
        ebay maybe?? You could always look into an aftermarket 5 speed if you don't want the 6 gears...
        or that ^^^^^^ posted at the same time lol
        -Dan
          Not too sure about 3rd gens but 4th gens need quite a bit of work to get a t-56 to work not to mention that it'll be slow as hell out of the hole (unless you have around the power of a v8) because 1st gear is so much longer in the t-56 as compared to the t-5.
          '99 SSM Camaro V6 M5
          Stock with an irratic idle...
          (218/218 .528/.528 112LSA 112IC)
            This is for a 3rd Gen Camaro just so everyone knows. I just want a direct replacement for the T5 but i was hoping for a new one.
              see if u cant get ur hand on a t-5 world class tranny, rebuild it correctly and it will be just as good when new
