My goal would be for an N/A engine, not a daily driver that might see occasional strip use, but mostly to just be a powerful street machine. This is just for the engine right now, rear and suspension, etc. will all be for later on. My goal is for something like 350-400 RWHP.
Block Bored +.040"
Rotating Assembly:
Forged 4340 Crank (maybe cast steel), 3.48" Stroke
Forged 4340 Rods, 5.700" Long
Forged Pistons, +.040" (about 10.4:1 compression)
All new gaskets and bearings (rebuild kit)
Valve Train:
Ported And Polished Heads (similar to the LE2 package), New springs, valves, etc.
Hardened Pushrods
1.6 RR's
Custom Grind Cam (probably from Comp. Cams)
Cloyes Double Roller Timing Set
Intake:
Ported Manifold
Cold Air Intake, Maybe Ram Air
52 or 58 mm T.B (thoughts??)
New MAF
Cooling:
Electric Waterpump
Manual Fan Switch
160* T. stat
Fuel:
Larger Fuel Pump
30/36 lb. Injectors
All running into 1 3/4" Long Tubes.
I still want to keep a good amount of torque down low too, as it will mostly see the street, but incase I want to run it at the track I want to have some good times. Hopefully I didn't forget anything, but if I did I'll try to fill in the blanks, anyways let me know what you guys think!
Block Bored +.040"
Rotating Assembly:
Valve Train:
Hardened Pushrods
1.6 RR's
Intake:
Ported Manifold
New MAF
Cooling:
Electric Waterpump
Manual Fan Switch
160* T. stat
Fuel:
Larger Fuel Pump
30/36 lb. Injectors
