I have an 88 camaro with only a standard v6 engine in it.. so making room and cleaning my bay should not be to extremly difficult... right?
For starters I was wanting to remove my EEC and relocate my battery. The battery relocation isn't where my concern lies... it is more in the EEC. It seems pretty simple to remove it is just all the hoses conected to it that have me worried that I will mess something up. Of course if the hoses aren't connected to anything then they need to go as well. But some of these hoses connect to hard lines that run to the back of the car and some connect to other vaccume lines that will still be connectd to something after removing the EEC. Might any of you have some words of wisdom to share???
Thank you in advance
For starters I was wanting to remove my EEC and relocate my battery. The battery relocation isn't where my concern lies... it is more in the EEC. It seems pretty simple to remove it is just all the hoses conected to it that have me worried that I will mess something up. Of course if the hoses aren't connected to anything then they need to go as well. But some of these hoses connect to hard lines that run to the back of the car and some connect to other vaccume lines that will still be connectd to something after removing the EEC. Might any of you have some words of wisdom to share???Thank you in advance
would I want to get a vented gas cap, or would I be better off leaving the pressure in the tank? The previous cars I owned ( rice burners ) all held pressure in the tank. Im sure it depends on the fuel system in the vehicle. Would my camaro be effected in a bad way by leaving this pressure in the tank?
