Heater core is clogged I guess. Getting very little heat. It was flushed out 2 years ago, and now its clogged again. Is this normal? How do I clean it out? Don't want to pay to have it done again.
Very little Heat?
To clean it just pull the hoses off the heater core, there on the passenger side firewall, get a garden hose and flush it out really well both ways. Then hook them back up bleed out your cooling system and add a little coolant and you should have good heat.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
you must be running dex cool...if you are, did you do a perfect 50% mix? too much dexcool in a mixture creates sludge.
Originally posted by 88bird5spdwhat ur t-stat temp? if its below 180* dont expect much heat
Originally posted by LimTeng99TransAmyou must be running dex cool...if you are, did you do a perfect 50% mix? too much dexcool in a mixture creates sludge.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Car runs on green antifreeze. Mixture is at least 50 50 if not more like 60 water 40 antifreeze. Normal operating temperature, and using a 180 degree thermostate. Coolant was slightly low. I filled it up to normal, and I'm still not getting much heat. The heater core was clogged 2 years ago. Hard to believe its clogged again.
94 Formula need more information. I need pictures of where the heater core is, and how to bleed the system.94 Formula LT1 (Aqua Metallic) - Auto. - 104,000 miles - Charcoal Leather Mods: Magnaflow Muffler, Lingenfelter CAI, MadZ28 Tune, 160F Hyp. T-Stat., 1LE Elbow, & Summit Cutout. Options: 155 MPH Gauge Cluster, & 255-50ZR-16 Tires.
What temperature should an LT1 with a 160* stat and programming for that thermostat run at? I have this set up and my temperature guage says it never gets above 130*.1993 Formula - 99k
Throttle body bypass, K&N FIPK II, SLP Loudmouth, Mad Z28 Chip, 3.73 motives, TPI airfoil, Spohn LCA relocation brackets, Fuddle 3200 Stall, B&M Supercooler, LS1 driveshaft, and chrome ZR1's 17"/9.5" and 17/11" in the back!!!
http://shbox.com/1/bleeders.jpg
The first pic is the bleeder screws. After your done just open them up with the car running and wait until it lets the air out and coolant begins come out of them. Be sure to put down towels to protect the opti. I couldn't find a pic of the hoses going into the firewall but if you look on the passenger side firewall they're the only heater hoses that connect there. If you look around the site some I'm pretty sure you can find a right up on how to do it.
Photo courtesy of shbox .1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Originally posted by 94 formulaGreen coolant will also clog your heater core and it will actually do it quicker since its life isn't as long as dex cool.
http://www.f-body.com/forum/showthre...hlight=dexcool
Originally posted by LimTeng99TransAm1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
After working in a dealership for 5 years I have seen many cooling systems clogged. Mainly due to the customer not knowing and pouring green coolant into a dex-cool system. Big mess.
I don't think GM puts anything in Dex-cool from the factory, the techs at dealerships sometimes put stuff in after a repair.2004 GTO - stock,FOR SALE.
1996 WS6 T/A - M6, LT4 Hot Cam, 4.10's, B&M Ripper, K&N, SLP Loudmouth, Eibach springs, Air foil, LG Plug wires, LG Engine bay brace, LG control arms, Harlan shift light.
You can most likely thank the DexCrap Coolant for your problems, I'm having the same problem with mine only mine started losing heat again about 6 weeks after the flush. Dealer wants 1100.00 to acid wash the system and install new heater core, NOT!!! I'm trying to make it until spring and will tear into it myself but I'm not a happy camper. I'm 50 years old and have had a Camaro or Firebird since 1974, I've never had to replace a radiator or heater core. Never even had a heater core plug up on me. I kept some of those cars 8 years and put 125k on them. Oh I know. I'm sure GM would tell me I have been maintaining my cars wrong for the past 32 years and been just plain lucky. They will play hard to sell me one of their new overpriced Retropean [ Retro/European] models when they come out. I wonder what it's like to have a business doing so well that you can just cast off loyal customers? LOL
I have green antifreeze in my car. Heater is working better now, but its not great. Good enough now, so I'm not bothering with it plus its getting warm here now.94 Formula LT1 (Aqua Metallic) - Auto. - 104,000 miles - Charcoal Leather Mods: Magnaflow Muffler, Lingenfelter CAI, MadZ28 Tune, 160F Hyp. T-Stat., 1LE Elbow, & Summit Cutout. Options: 155 MPH Gauge Cluster, & 255-50ZR-16 Tires.
