There is absolutely nothing wrong with Dex-Cool. It got a bad rap because the vast majority of people do not mix it 50/50 with water like they are instructed to. Most people will tell you they just poured in one gallon of Dex-Cool and then topped off the radiator with water.
Dex-Cool is more sensitive to being mixed properly than the green stuff, so this makes it even that much more important. If you dilute the Dex-Cool too much with water, you increase your chances of the coolant/water mix becoming acidic and electrolysis occuring. This is the number one cause of heater core and radiator core failure.
If you have to rich of a mixture(too much Dex-Cool), you significantly increase your chances of crudding up your coolant system.
I personally think the Dex-Cool claim of 5 years or 150k miles was an overshot. I would still flush and change the Dex-Cool every couple of years. Make sure you mix it as close as possible to 50/50.
Most pro's that I have talked to and/or know, discourage the use of distilled water in an automotive coolant system. The primary reason is that purified or distilled water, can actually have a defervescence effect, effectively raising the boiling point of the coolant system. Distilled water not only has a higher boiling point than that of common tap H20, but it's boiling point is very unstable.
Also, distilled water can often become deionized upon the distillation process. This is also not good for a coolant system, because it will exacerbate the potential for damaging electrolysis to occur.
The problem is not the Dex-Cool, it's the owner. I've worked on dozens upon dozens of GM cars that were maintained well by the owner and never had a single problem with their Dex-Cool cooling system. You just need to inspect a Dex-Cool cooling system every so often just as you would any other cooling system.
