does anyone know where i can find after market fuel rails? i installed nos noszle direct port system, it changed the angle of the injectors and they wont seal. does anyone know how to shorten the crossover tubes?thats the only thing i can think of to get the right angle for the injectors to seal.it looks like i will also have to drill out the intake on the same angle.does anyone have the same nos kit on a lt1? need help.
nos noszle kit trouble
Kinsler has about the best selection of fuel injection parts available, including rail stock:
http://www.kinsler.com/
I assume you raised your stock rails up equal to the added height of the NOSzles. It would seem as the injector gets "longer" (when you add the length of the NOSzle), the bottom of the actual injector would need to move outward, meaning the top would have to move outward the same amount to keep the angle the same. In which case, you have to widen the cross-over tube, rather than shorten it.
My suggestion would be to replace the cross-over tube with a braided SS line. Are you still using the stock configuration... in the back of the passenger side rail, and out the back of the driver's side rail through a stock FPR?
Kinsler makes some evil stuff....
