i was wondering if it is possible to run true duals off the headers to the side of the car, infront of the rear wheel on a 94 firebird formula? I was told it was possible with about 2 1/4-2 1/2 inch pipe. But i need someone else opinion.
true duals exhaust pipes out the side?
It is possible - guy in the local club has them - he has them with NASCAR boom tubes - very cool.Silver 02 WS-6, 6 speed, Corsa cat-back, SLP lid, K&N filter, BMR STB, !CAGs, Lou's short stick, MSD wires, MTI "Hammer" cam, ASP underdrive pulley, Hooker LTs, Hooker ORY, Comp 918s, TR pushrods, UMI Sfcs, UMI LCAs, NGK TR55s, Hotchkis springs
i was just worried about clearence..what ppe size should i use all the way back? and what are boom tubes? are they kind of like chambered mufflers that is crimped? if you know what i meanOriginally posted by casey02ws6It is possible - guy in the local club has them - he has them with NASCAR boom tubes - very cool.-Jeff
My exhaust runs to the rear axle, and has turndowns (pointed "inward" to try and meet the local track noise limits). It wouldn't be that hard to add a bend and aim them over to the sides, in front of the rear wheels.
Originally posted by InjuneerMy exhaust runs to the rear axle, and has turndowns (pointed "inward" to try and meet the local track noise limits). It wouldn't be that hard to add a bend and aim them over to the sides, in front of the rear wheels.
that is pretty nice, what size is your whole system? i was thinkin about running 2 1/4- 2 1/2 but im not sure what will work. I am also looking at the chambered exhaust mufflers in the summit catalog, its a straight through muffler that is crimped about three times, all the way down. look for yourself, people i work with tell me they sound amazing on f-bodies. it also helps that i work in a muffler shop!
get these things at a discount. thanks for your help
-Jeff
I have the AS&M headers, and 3" extensions on the collectors, then a Borla 12" long 3" XR-1 muffler (straight thru), and then the 3" pipes to the rear axle. Its pretty loud.
Previously I had the same exhaust through the Borlas, a 3" Y-pipe to a 4" Mufflex catback. The "Y" wouldn't fit after I put the Gear Vendor O/D unit in, so I removed the Mufflex to save weight (its weighing down Joe 1320's car now
) and had Mufflex make me the 3" dual pipes.
Originally posted by InjuneerI have the AS&M headers, and 3" extensions on the collectors, then a Borla 12" long 3" XR-1 muffler (straight thru), and then the 3" pipes to the rear axle. Its pretty loud.
so you can fit 3inch pipe under an f-body? if i read your post correctly..-Jeff
If you are worried about ground clearance, you can buy 3" ovalized pipe and accessories
Oval pipe
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Dang.... and I thought that Mufflex was throaty.Originally posted by InjuneerMy exhaust runs to the rear axle, and has turndowns (pointed "inward" to try and meet the local track noise limits). It wouldn't be that hard to add a bend and aim them over to the sides, in front of the rear wheels.
The turndowns pointed inward must make the interior resonate like a %^&*%^&*%!
Whaddaya say? Can't hear ya........Originally posted by Joe 1320Dang.... and I thought that Mufflex was throaty.
The turndowns pointed inward must make the interior resonate like a %^&*%^&*%!Fred
Originally posted by DeWynterIf you are worried about ground clearance, you can buy 3" ovalized pipe and accessories
Oval pipe
thanks for that website, i knew there was a way to get oval tubing. ive never seen it but its the only thing that makes sense on low sitting cars. but one thing, lets say i would get the oval tubing, then my muffler will be three inch in diameter..so no matter what i do i will be scraping something. So i might just stick to regular tubing. like i said, being i work in a muffler shop, i get almost anything i want at manufacters price, its pretty nice. but not everything... thanks for your help everyone.-Jeff
I went with 3"Chambered exhaust and have no clearance problems. I only used the oval pipe to exit out the side of the car in front of the rear wheels as that was the low point for me. I ran it along the trans tunnel and then out past the end of the front/center frame rails that run by the trans.Originally posted by 94formulaLT1thanks for that website, i knew there was a way to get oval tubing. ive never seen it but its the only thing that makes sense on low sitting cars. but one thing, lets say i would get the oval tubing, then my muffler will be three inch in diameter..so no matter what i do i will be scraping something. So i might just stick to regular tubing. like i said, being i work in a muffler shop, i get almost anything i want at manufacters price, its pretty nice. but not everything... thanks for your help everyone.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
