The 26918's are 130 lb and may be a little too much for your stock lifters. They also make a beehive in a 105 lb, it's the 26915. Some guys use the LS1 retainers on the 918's and the 915's but you don't have too. The stock steel retainers or the 787's will work just fine. You can also go with the LS1 Titanium 772's. You can also use the stock locks with the steel retainers.
On aluminum heads with the 918's or the 915's you shouldn't have to touch the spring pocket or touch the springs. If anything you might need to run a valve spring spacer/shim to obtain the correct 1.800" install height. I have seen guys install them without any work to the spring pockets and/or the springs, but you know how engine building goes, every motor is different.
The 918's hit coil bind at roughly .660", so the .600" lift is fairly conservative. You could run .630" with no problems.
