I was driving down the road when I noticed that my I had a big cloud of smoke behind me all of the sudden. I pulled over and there was fluid gushing out the bottom of the car and hitting the exhaust. After getting it towed home and looking further into it, it's coming from the back of the torque converter and the front of the transmission. I'm sure it's not coming from the tranny pan because I took off the torque converter cover and started it. When I put it in gear it starts pouring out. It's probably the pump bushing and seal right? So that would probably mean that I'll have to have somebody take the transmission out? How much do you suppose something like that is going to cost?
Leaking a ton of tranny fluid.
u can drop the tranny urself, drain whats left of the fluid, disconnect the d/s, any electrical connections, then the bellhousing bolts, pull back(using a jack of course and a buddy) and lower. estimated savings - 200-400$2009 Honda Civic EX- the daily beater
Anybody else know how hard it is to do yourself? Should I put a higher stall converter in while I have it apart?
1993 Formula - 99k
Throttle body bypass, K&N FIPK II, SLP Loudmouth, Mad Z28 Chip, 3.73 motives, TPI airfoil, Spohn LCA relocation brackets, Fuddle 3200 Stall, B&M Supercooler, LS1 driveshaft, and chrome ZR1's 17"/9.5" and 17/11" in the back!!!
Sounds like the front seal. When you place the trans into a gear, it sends pressure through the input shaft into the converter to keep the converter clutch disengaged. It's an easy do it yourself fix, but you just have to drop the trans.
I had the same issue it was the front seal. The part is cheap. It is just a dirty job to do. Funny I had the cloud too. Trans fluid was dripping on my cat. Looked just like the spy hunter video game.
96 Camaro Z28/A4,Vortech elbow,Moroso CAI,Flowmaster.Addco PHR,LCA,160* Stat,pcmforless,1LE Driveshaft,1LE A/C delete pulley,1LE Front sway bar,Strut brace,sub frames, LT4 knock module,255 lph pump,Cutout,
What part of this picture do I need to replace? http://www.zmydust.com/images/converter/P8240021.JPG
The seal around the base of the imput shaft or is there a seal under the 7 bolts that go in a circle? I'm to this point. I'm just
on some parts to come in.
1993 Formula - 99k
Just the seal around the input shaft. The 7 bolts retain the bearing.Originally posted by blackfire93What part of this picture do I need to replace? http://www.zmydust.com/images/converter/P8240021.JPG
on some parts to come in.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Well, I just got my tranny all back together with a new front seal. I ended up putting a fuddle torque converter in with a stall of 3200 rpm. I took it out for a drive and the output shaft leaks a little so I replaced that seal too. With the new seal it still leaks out the output shaft. Then I drove it for about 30 more miles and now the front seal is leaking again. Not as bad as it was at first but still pretty good. I think it might be because I had trouble getting the torque converter in and had to pull it off and on so many times. Anyway I have a senior graduation party that I need my garage for so I'm gonna have to send the car to a shop so that they can worry about it. Thanks for all your help though.
1993 Formula - 99k
Ok, I've been shopping around for a shop to have fix the front seal, but they all say that they won't just replace the front seal and they want to rebuild the transmission for lots of $$$. I think I'm going to try and replace it one more time by myself. Could stabbing the torque converter too many times have caused the new seal to go bad? Thanks for all your help.
1993 Formula - 99k
