The dealership should be able to do it for you. I can if you get it to Atlanta. You could get a "tune" from someone like MadZ28 or PCMforless. They can do an exchange for you computer.
Speedometer problem on T-56
i'm actually driving through georgia in about 3 weeks, that would be a good time to get the pcm tuned and speedo fixed, can u give me any specifics on the location. i'm sure they have a website.1995 Firebird Formula. LT-1 6 speed, underdrive system, k&n cold air intake. SLP exhaust no cats. just got the car, list will grow
me .Originally posted by 6spdLT1Birdaccording to their websites, they are located in Pennsylvania and Illinios.. what might be in Atlanta?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
I can put the correct stock programming in it to fix the speedometer problem.Originally posted by 6spdLT1Birdoh i see, so u can tune the PCM to the specs that madz28 or PCMforless can??2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Yes I like my shifter a lot.Originally posted by 6spdLT1Birdso do u like that hurst shifter you put in? i'm thinking of buying the b&m or the hurst2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
i actually emailed madz28 about whether the code in the PCM is programmed for the auto transmisison instead of the manual. they said if that was the case, then the SES light would come on because there would be extra codes for the shift points and ect.. . is it possible that only the speedometer code is wrong but the rest of the codes for T-56 are correct? if the PCM is in fact the problem, i'm driving from South Carolina to Florida in the firebird early/middle May, than a quick edit to the PCM would be spectacular!!1995 Firebird Formula. LT-1 6 speed, underdrive system, k&n cold air intake. SLP exhaust no cats. just got the car, list will grow
Hey...been following along and I just thought of something.
Does the car have a functioning 1st to 4th skip shift circuit? Or, is there a skip shift eliminator on the VSS?
The reason I'm asking is because to correct the speedo on mine after doing the skip shift eliminator, I used a black box that needs to be adjusted. Turning pots. adjusts the speedo up or down.
Perhaps there is a black box that you don't know about connected to the VSS?Al 96 Ram Air T/A
Originally posted by Al 96 Ram Air T/AHey...been following along and I just thought of something.
Sinse when does disconnecting the skip shift have any impact on the speedometer/VSS calibration??
I've unplugged a few CAGS circuits and never have I seen it affect the speedometer accuracy. It's completely unrelated.
You know what...you're right. I'm getting my mods. confused. It's been so many years now...I forgot. I had to use the black box after I did the gear change...not the skip shift eliminator. My bad...Al 96 Ram Air T/A
LOL! Momentary lapse of reason. Are you one of the old farts on this forum?Originally posted by Al 96 Ram Air T/AYou know what...you're right. I'm getting my mods. confused. It's been so many years now...I forgot. I had to use the black box after I did the gear change...not the skip shift eliminator. My bad...Tracy
Well, not in age (only 35), but in terms of being on this site...I guess. Been a member since day 1...over 10 years now.
And the momentary "brain fart"...that's caused by three kids under the age of seven (LOL)
Al 96 Ram Air T/A
I feel your pain. I'll be 33 this June and have 3 kids under the age of seven as well. My oldest son will be 6 this July. Sometimes I feel like someone used a blender to scramble my brains.Originally posted by Al 96 Ram Air T/AWell, not in age (only 35), but in terms of being on this site...I guess. Been a member since day 1...over 10 years now.
Maybe his speedometer fluid is low? If the fluid were low that could easily explain the low reading on the gauge.Tracy
