I got an oil leak on the driver side rear of the block somewhere on my 88 350 (L98), it drips down right over the oil pressure switch and filter. It's a really heavy leak, only leaks while the engine is running. I was thinking it was the rear of the intake manifold gasket so I replaced that, same exact amount of leakage after. So now i'm thinking maybe the distributor shaft gasket, rocker arm cover gasket...but it doesn't look like those are leaking...what else is back there that could be leaking?
Need suggestions on oil leak
Oil presure sender?Tracy
I think you might be right...I just went at it with some dye, a mirror, and a UV light and it's definitely not coming from anywhere above the transmission bellhousing. It's basically pouring out from somewhere directly above the oil filter...i'm gonna lift it up at work tonight and see exactly where.'88 Formula 350
