When exactly should the cooling fans on my car be running?
Are Fans Always Suppose To Run
I can't remember the exact temperature they come on, i think 210 and 225. Some one will know for sure. And no they don't run all the time.
Oops just realized, that you have a third gen. Don't know the fan kick on temp but i think they don't come on till they hit a certain temp.2006 Saturn Ion Redline
2003 Mits. Eclipse Spyder
should come on around 225*F. Also they are supposed to run all the time the A/C is turned on.
Bruce, μολων λαβέ
Originally posted by bru333should come on around 225*F. Also they are supposed to run all the time the A/C is turned on.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff 95 Z28When the A/C compressor is engaged.
Also, if you pull codes with the paperclip trick the fans will run all the time the ALDL is jumpered with the key on.
Bruce, μολων λαβέ
Originally posted by LimTeng99TransAmright...but only in low. They still don't turn on high until 225* if I'm not mistaken...unless you tuned for lower setting.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Fan Turns On When....
My 88 Camaro turns its fan on at 210 temperature wise and whenever the A/C is engaged. However, my fan is controlled by switches versus your 89 is controlled by the computer. Hope this helps.1988 5.0 TBI Camaro 700R4 Transmission
im not sure if you really care, but me and my buddy and a manual fan bypass switch on his 84 T/A today. It was a breeze and i personally think its a great mod that was just plain easy. Kept the engine real cool, great for keeping everything running effiecently!1994 formula A4 w/ 84,XXX MI, bone stock except MSD wires and NGK TR5 plugs
Thanks for the info guys, I just put on a manuel fan switch as well, but being slighlty inexperianced with the electrical I can only get one fan to come on, ever (i think maybe one of the motors is burned out) but ill get around to fixin it up when I have some time1989 Camaro IROC-Z 5.0 TPI Auto (Away For Winter)
-Flowmaster With 3 Inch SS Tips
1989 Plymouth Reliant 2.5 TBI Auto
-65,000 Original KM And No Rust Beater
Dual Fans
If you have dual fans, one is for the A/C and the other for the temp sensor. Your computer will control both. One with the temp sensor and the other with the A/C request sensor. Running engines too cool is not efficient. Engines need to get to their operating temperatures to run best.1988 5.0 TBI Camaro 700R4 Transmission
