How much does a stock 98' - 02' z28 weight and a 98'-02' trans am ( 8cyl)?
Weight
Weight
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
Between 3,300lbs and 3,600lbs or so depending on options.Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
SOLD- Good riddance!
Thats what i thought, cuz thats what it says on like auto trader under specs and stuff, but this guy had a pic of his car like the door and it said 4200 lbs... its weerd.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
That's the maximum amount of weight the car can hold, including itself. So say the car weighs 3,400lbs and the number on the door said 4,200lbs (not sure what that's called), it can hold another 800lbs between passengers, luggage, etc.Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
GVW or Gross Vehicle WeightOriginally posted by NightrageThat's the maximum amount of weight the car can hold, including itself. So say the car weighs 3,400lbs and the number on the door said 4,200lbs (not sure what that's called), it can hold another 800lbs between passengers, luggage, etc.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Thank you! I drew a mental blank.Originally posted by DeWynterGVW or Gross Vehicle WeightRed 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
