To my understanding, the 98's were the only ones to get Auburn's standard. In 99, GM started to put Zexel-Torsen's in all the LS1 cars as standard regardless of whether or not they were a SS or WS6. There were some 99+ LS1 cars that recieved Auburn's as an SLP build option, but it was not a factory standard.
1/4 times and stock rear end ratio
Why were on the subject, which diff is better? Auburns or Torsens? Cause I'm under the impression that Auburns are better...
Crap. I meant to say I thought all 98-02 (V8s) got Torsens and only SSs and Firehawks got Auburns? According to the Torsen website www.torsen.com they started putting them in F-bodies in 1998 not 1999. SLP used to list the Auburn in the SS and Firehawk sections as 98-02.
As to which is better it depends on what you want to do. For straight line drag racing the Auburn is better than the regular Torsen. For handling ie road coarse autocross or just street driving the Torsen is better. I am very impressed with the Torsen. It really helps keep the rear end planted when turning. The stock Torsen will spin the right rear tire when turning right if the left rear is getting really good traction. If it isn't it will drive both tires and kick the rear to the side like a true limited slip. I don't think I have ever had it spin the right rear and not the left rear in a straight line acceleration. In loose road conditions I think the Torsen is better in straight line than the limited slip. It tends to transfer power where needed rather than just spin.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff 95 Z28Crap. I meant to say I thought all 98-02 (V8s) got Torsens and only SSs and Firehawks got Auburns? According to the Torsen website www.torsen.com they started putting them in F-bodies in 1998 not 1999. SLP used to list the Auburn in the SS and Firehawk sections as 98-02.
There were(and maybe still are) a few threads where people were taking pics of their RPO codes and their rear-ends with the covers off. None of the non-SLP-optioned 98's had any Torsen's.
I agree, the Torsen is probably the better road corse rear-end and the Auburn is better suited for straight-line applications. Although the Eaton is even stronger and better than the Auburn in straight-line applications. Just have to do the swap.
Originally posted by fastTAThat is interesting, although I never really trust the year spans that aftermarket manufacturers put on their site. There were some links on ls1tech.com to a few GM official sites where GM stated that the 99's were the first year of the Torsen being standard. SLP is correct in listing the Auburn as available from 98-02..... because it was.
I agree, the Torsen is probably the better road corse rear-end and the Auburn is better suited for straight-line applications. Although the Eaton is even stronger and better than the Auburn in straight-line applications. Just have to do the swap.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Trust me, all 98 LS1 F-body's got Auburn rears from the factory as a standard component. The 98 cars could order a Torsen as a factory upgrade or a SLP build option.
The Auburn's that are in the 98's are limited slip. 98 was a first production year for the Gen III F-body's, so who knows why GM decided on that one
Originally posted by fastTATrust me, all 98 LS1 F-body's got Auburn rears from the factory as a standard component. The 98 cars could order a Torsen as a factory upgrade or a SLP build option.
Who has a 98 LS1. Jack up the rear end and spin 1 tire. Does the other side spin the same way or the opposite way.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff 95 Z28No thanks. I don't believe GM used Auborns in production cars. I need proof.
It's common knowledge amongst LS1 owners that the 98's came with Auburns.
Do a search on ls1tech.com if you don't trust me and need further proof. I already have mine.
Originally posted by fastTAI've worked on many 98 LS1 cars and it's quite easy to see if the rear-end has the invex gears as per a Torsen, or the clutches and common yellow springs associated with an Auburn. Guess what..... all the 98's have clutches and the good-ole yellow springs back there.
In this thread it takes several posts before someone finally says that his differential doesn't have anything to wear out.
http://www.ls1tech.com/forums/showthread.php?t=491523
There are many threads on there that are just not correct. I don't get that warm fuzzy feeling that these people are that knowledgeable.
Guess what, the rear end I took out of my car had yellow springs and clutches in it. I gave it to a friend and when I see him I'm going to get him to take a picture of it. It is a stock 95. Does that mean since it had yellow springs that it was an Auburn? Maybe the stocks springs are yellow too. Maybe they meant Auburn "style" when referring to a stock rear end.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff 95 Z28Guess what, the rear end I took out of my car had yellow springs and clutches in it. I gave it to a friend and when I see him I'm going to get him to take a picture of it. It is a stock 95. Does that mean since it had yellow springs that it was an Auburn?. I simply said that it was common for the Auburn's to have yellow springs. Eaton's can have yellow springs as well....what's your point. Anybody, however, can tell the difference between a invex(worm) gear differential and a clutched differential.
I don't expect everyone to have an intimate knowledge of the LS1 cars, so it it is OK that you didn't know.
I'll say it one more time. I have worked on many 98 LS1 f-body's, and I have done my research on this subject. ALL 1998 LS1 f-body's(with the minor exception of Torsen special orders) came STANDARD with differentials built by Auburn Gear, not "Auburn-like" differentials.
Originally posted by Jeff 95 Z28Maybe they meant Auburn "style" when referring to a stock rear end.
Part of a sticky on LS1Tech. Bear in mind, this board's stickies are reviewed by the best pro's in the nation and I just happen to stay in contact with a significant portion of them:
http://www.ls1tech.com/forums/showpo...85&postcount=7
