after head
  • after head
    today i have cylinder heads install.but there is one problem. when i drive my car and step little bit hard on gas pedal, smoke just come out alot from the tail pipe, its like i did aburnout. why is that like that?
    thank you
    2001 Trans Am WS6 M6
    probably burning of oils and greases from all the handling of parts. I know that why you get stuff like headers oiled up, they smoke
      white or blue smoke?
      White would indicate coolant, blue would indicate oil. One of the two is getting into at least one cylinder to cause the smoke. Did you have any issues with your head gaskets? Could one of the heads be warped and not sealing properly?
        A little smoke is normal after firing up the motor for the first time after a head install, but not "burnout"-like smoke. Take it straight back to whoever installed your heads and show them what it is doing.
