If been running regular oil in it ,should I switch to synthetic for better performance ?[B]
Can I simply switch to synthetic oil anytime ?
you can but some ppl say do it gradually because the synthetic is said to be able to knock old oil deposits loose and can cause problems, but many ppl just do it all at once and not have a prob so really its up to you.1990 Eagle talon TSI- daily driver
78' firebird formula -350/350- stock...now dead
synthetic doesnt give u any better performance, just protects against wear moreOriginally posted by lavapearlshould I switch to synthetic for better performance ?[B]2009 Honda Civic EX- the daily beater
Yes you can switch over, as long as you change everything like the filter, or drain it out, witch u will probably do anyway. And usually synthetic is a little big easier for the crank to tread through, but its extremly minimal.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
1969 z28 - 9.957 @ 133.92 1.425 60 foot.
Originally posted by 88bird5spdsynthetic doesnt give u any better performance, just protects against wear more
I disagree. Im not saying it gives a big performance boost, but I have seen a few dyno test in car mags(Hot Rod is the main one that comes to mind) and it seems in most cases you can pick up about 5hp from synthetic oil.1994 Z28 Camaro-Project carbed 4th gen
1995 Silverado-beater truck
2005 Colorado Z71-Daily driver
Actually, yes it does give you a performance boost. Less friction in the valvetrain will free up some HP, which is generally what synthetic oils do. Do some research and you'll change your mind.Originally posted by 88bird5spdhow is that? im not talking bout going from 20w50 to 5w20 either, i just dont beleive it
As for switching to synthetic, I've changed all 3 of my vehicles over to synthetic from convential oil without any gradual periods. Just switched straight over, no problems. I'm running Royal Purple in all 3 and highly recommend it if you have the money.Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
I have seen Combination Motorsports take a shortblock done by "another" shop and gain over 25-30 RWHP by merely re-honing the cylinders correctly to a zero tolerance. Nothing else. The reason you ask?......less friction.Originally posted by 88bird5spdhow is that? im not talking bout going from 20w50 to 5w20 either, i just dont beleive it
Synthetic oil does the same thing. Less coefficient of friction between the cylinder walls and the rings and skirts, and less friction between the bearings and journals equates to freed up HP.
