I just had new o2 sensors put in and took the hypertech promgram out of the car and it still failed miserably. I have long tube headers, but i believe there street legal, they have all the emmissions stuff necessary. I still have a cat and i just did a tune up no more than 5000 miles ago and did a new opti about 500 ago. I've also replaced my egr valce recently? I was wondering if maybe wait a week to have it recalibrate itself, put some good gas in it and some additives. Think that'll work?? or any other ideas??
Didnt pass Inspection due to emmissions
is california the only state that actually test emissions for the inspection stickers? mississippi only tests lights, horn, blinkers, and windshield....im guessing you guys are in cali.LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1
With long tubes, they move the position of you cats. Which is illegal. So if they did a visual inspection, then you probably failed. I would guess you either have to put you stock manifolds back on, get it inspected, then put the long tubes back on....or go with mid-lengths.
good luck either way you go2006 Saturn Ion Redline
2003 Mits. Eclipse Spyder
There are plenty of other States that do a sniffer test. Some (like CA and NJ for example) use a tredmill/rolling road and test at speed. Here in NC only newer (OBDII) vehicles get tested, and only in certain counties.Originally posted by LarryMowis california the only state that actually test emissions for the inspection stickers? mississippi only tests lights, horn, blinkers, and windshield....im guessing you guys are in cali.
Bruce, μολων λαβέ
That's not enough info for anyone to help. Post your test results. What parameter failed you? What cat do you have?Originally posted by 95BadMotorScooterI just had new o2 sensors put in and took the hypertech promgram out of the car and it still failed miserably. I have long tube headers, but i believe there street legal, they have all the emmissions stuff necessary. I still have a cat and i just did a tune up no more than 5000 miles ago and did a new opti about 500 ago. I've also replaced my egr valce recently? I was wondering if maybe wait a week to have it recalibrate itself, put some good gas in it and some additives. Think that'll work?? or any other ideas??
Here in Pennsylvania it is only in the major cities that you need to pass an emissions test...like where I am (Allegheny County, Pittsburgh)Originally posted by LarryMowis california the only state that actually test emissions for the inspection stickers? mississippi only tests lights, horn, blinkers, and windshield....im guessing you guys are in cali.
2002 Firehawk Sold
I'd be more inclined to blame the cats..... high HC is generally produced by a rich mixture, but a rich mixture will reduce NOx. NOx comes from a lean mixture. High HC and high NOx would appear to be related more to a weak or failed catalytic converter.Fred
