UPS just dropped off my SLP manual fan switch today. Looking at the instructions, it doesnt look like its gonna be much hassle. Has anyone else put one in before? Any tips? Any suggestions as to where to mount it? If my XM radio wasnt there already, Id make a face plate and mount it in the console in the little storage cup in front of the ashtray. Thanks for any ideas or tips.
SLP Fan Switch
SLP Fan Switch
LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1Tags: None
Easy greasy...the hard part would be mounting the switch. I mounted mine on the center consol.
If you pull the PCM there is a grommet from the engine bay to the inside of the car ..on my vert there is a blank plate next to the vert top switch1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
I've just gotten home and am about to uncover the TA and take it out for the first spin. I have the switch aswell and will try to install it soon.
Lets us know how it went.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
Thanks for the pix....after seeing those, Ive pretty much decided thats where I'll put mine. Since I dont smoke, it wont be a problem.LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1
I used a small piece of polished 20 ga stainless. Sorry my picture is so crappy (it was meant to be a pic of the interior, not necessarily the ashtray), it actually is pretty trick - I have the aux fuel pump, 2 fans, elec cut out, line lock enable, and antenna defeat switches in there - 6 in all. Designed the little piece in CAD to get all the holes where they needed to be. Make a pattern out of cardboard first. You can put your screw holes in the LL and LR corners. I had some plated steel in there at first, but it looked like crap - probably could have used aluminum & clearcote it to keep it looking nice.
it looks real good, i wanna put gauges in the vents as well. was that a PITA?Originally posted by Kevin - Blown 95 TAI used a small piece of polished 20 ga stainless. Sorry my picture is so crappy (it was meant to be a pic of the interior, not necessarily the ashtray), it actually is pretty trick - I have the aux fuel pump, 2 fans, elec cut out, line lock enable, and antenna defeat switches in there - 6 in all. Designed the little piece in CAD to get all the holes where they needed to be. Make a pattern out of cardboard first. You can put your screw holes in the LL and LR corners. I had some plated steel in there at first, but it looked like crap - probably could have used aluminum & clearcote it to keep it looking nice.1996 Trans Am WS6
A4, 3" VForce Catback, Corvette C6 rims, Slotted and Drilled Rotors, 160*stat, BMR SFC, HPP3, B&M Shift Kit.
Not too bad to put the gauges in the AC holes. It's a trick to pry the eyeballs out without busting them, though. Then you need to run whatever wires and lines from the gauges out a small hole in the back of the AC duct to wherever they need to go. If you get Autometer gauges, you need the 2 5/8" ones to fit the holes - they just press right in and stay there with no clamps or brackets. Use the red lights inside the gauges to match the interior lights and wire them to the dimmer circuit so they are the same brightness as everything else on the dash.Originally posted by redws6it looks real good, i wanna put gauges in the vents as well. was that a PITA?
yeh i have a air fuel ration and a vacuum gauge on the a pillar with the red lights and hooked to the dimmer switch, its amazing how the red matches the gauges in the car.1996 Trans Am WS6
well i just got my fan switch in...only took about an hour for the actual install. the longest, most PITA part was making a face plate for the switch...i decided to put it where the ashtray was like Craig and Kevin did theirs. since i didnt have any scrap metal laying around, i made mine out of some sheet plastic i had left over from my model cars...then lettered the on/off settings, painted it gunmetal gray which is almost an exact match for the dash/console. Luckily the ignition has to be on for the switch to work, so at least i wont ever run down the battery if i forget to turn it off.LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1
Update: well i took my ride out for the 1st time since installing the switch. Without the fan on, the car ran about 220...with the fan on, about 180. I didnt think it would be that much, I was pleasantly surprised.LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1
