Hey guys, i rescenty had 3.73 gears installed and went smooth, UNTIL next day i tryed starting it up in the morning and it didnt want to start, i kept cranking it hbut it wouldnt start, finaly i got it started, the idle shot up to 2k rpm and stayed there for about 30 sec or so, I let the engine warm up a bit, but when i put it into drive the motor felt like it was starving for fuel wanting to shut off on me. I took it for a spin around the block and it was stuttering, then i put it into park and reved it a bit and at first it choked and then reved up, the second time i did reved it it choked and motor shut off, had a hard tme starting it again, but did. Any ideas on what can be causing this? Could it be that i need to get the PCM tunne or would this be more of a mechanical problem?
P.S. I had rescently removed the screen in the Mass airflow sencor, being very carefull not to damage the coils inside. could that be whats causing it also? and if so would i be able to use a MAS from a 96 Lt1 (my brothers car) to test it?
