Go with the Bilstein HDs. If I wasn't rebuilding the Koni's on the GN, that's what I would be going with. Just make sure to double-check the part #(s) first. Summit sells the Bilsteins for the 4th Gen, but if you check the part #s they're the softer SLP Bilsteins, not the HDs.
If you really want to start getting serious, my suggestion would be the rear coil-over kit Spohn sells with QA1 components. Just my 0.02.
