what do i need to do to make a set of 94-95 mack shorties fit my 93 formula . ps hello all sorry it has been a while since my last vist
94-95 mac headers into 93 formula
mirror burn out movie top ten burn outsTags: None
The only "difference" will be the connections for the EGR and AIR systems. The 94/95 headers have a single connection for the EGR tube, and two connections for the AIR tube. Your 93 combines the EGR tube and one of the AIR connections into a single connection.Fred
that is on the pasenger side isnit on my 93 there is a fitting at the back of the stock manifold where as on the headers there is a fitting at the front and a small tube with a flange coming off the rear most header tube . will i need to block off the front fitting for the air and could i use some egr parts from a 94/95 car to hook up the egr ?http://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
You need to talk to another 93 owner. I know the 93 passenger AIR tube wraps around the back of the intake manifold, and connects to the EGR tube from the passenger side manifold, and then they connect to the back of the intake????
If you wanted to keep the stock 93 plumbing, it would probably work. You would just have to plug the AIR hole on the passenger side primary tube (#4???). But I don't know if the MAC headers use the stock fittings (M22-1.5 plug) or need some sort of adapter for the AIR connections.Fred
I believe you'd need to do some extra plumbing for the pass. side AIR tube. On the 93, the AIR tube hooks up on the back of the manifold, 94-95 on the front and the EGR tube is way to small. You would need to block the EGR fitting and extend the AIR fitting somehow to make it work...I believe. Hope this helps.Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
thanks would i be beter off junking the egr and air all together if so what is involved and would this cause the ses light to come onhttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
Only do this iff (that's if and only if) you don't have to worry about emissions.Originally posted by bigtowthanks would i be beter off junking the egr and air all together if so what is involved and would this cause the ses light to come on
Hardware-wise, you'll need to pull the AIR tubes, AIR pump, EGR valve, EGR solenoid and EGR lines. You'll also need the EGR blockoff plates, AIR plugs, block-off for the EGR port on the intake and a block-off for the AIR port on the intake/CAI.
PCM-wise, you'll have to have a custom chip made with the AIR and EGR functions deleted.
Me personally, I would either find a set of 93 headers or, if you really want the 94-95 headers, just find a way to extend the pass. AIR tube and block off the EGR port on the pass. header. Its really not worth getting rid of the AIR and EGR systems, esp. since its not really necessary, and connecting the AIR tube on the pass. side to the header shouldn't prove that hard if you're a little...inventive...with it
. Hope this helps.
Steve
Mods
Mods
Mods
thanks again i am using 94/95 headers because that is all i could get while i was on vacation in florida (i live in the uk ) i will give it some thought and have a go when i get some time off workhttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
Anytime
. Let me know how it turns out.
Steve
Mods
Mods
Mods
