I've been looking off and on for the past few weeks for production numbers for the 93s. Specifically, I'm wondering how many 93 hardtop 6-speeds were made and what number mine was. Does anyone know or know a site with detailed production information? Thanks.
Production numbers
Production numbers
87 GN - its just a 6...Mods
93 Z28 - slightly tweakedMods
Tags: None
Nobody can help after 26 views, huh?Steve
To my knowledge there is no such record of specific option combos actually produced, and there is no serial numbering (production number) of specific option combinations. Your "production number" is the last 5 digits of the VIN. The plate on the driver's door tells you what month it was built.
There are sites that show the number sold of each option, and you could get a mathematical estimate of how many were made of a particular option combo by multiplying the percentage of cars equipped with each option times each other.
Total 93 production: 39,103
All were coupes, so then you need to deduct the number of t-top car = 39,103 - 3,340 = 35,763 hardtops.
There were 31,691 built with A4's, so that leaves 39,103 - 31,691 = 7,512 manual trannies, but that include M5 V6's and M6 V8's.
Other options:
Base Coupe: 21,253
Z28 coupe: 17,850
1LE: 19
Power seat: 19,348
Power Locks: 32,970
P. window: 32,397
Power hatch: 38,477
B4C: 135
Indy 500 pace car replica: 633
Body side molding: 30,658
Rear defogger: 30,658 (seems odd its the same # as moldings???)
AC: 38,949
Remote mirrors:32,397
Perfromance axle ratio: 14,428
Block heater: 552
Cruise: 38,486
Aluminum wheels: 34,792
Z-rated tires: 16,419
235/55 tires: 18,373
Fog lamps: 38,487
Bose/cassete: 10,178
Bose/CD: 10,740
CA emissions: 4,419
Base group???: 737
Option pkg 1: 6,148
Option pkg 2: 32,218
PAINT:
Pace car black/white: 633
Arctic white: 1,506
Dark gray-green metallic: 4,350
Black: 9,655
Patriot Red: 6,903
Bright red: 11,136
Purple Pearl: 4,920
I didn't proof the typing, if you want the checked numbers, buy the "Camaro White Book".Fred
Thanks a bunch Fred, that helps a lot. So, the rough ratio of A4's to manuals is 4.2:1 for the hardtops, correct? If so, then I could just use this ratio to get a rough estimate of how many other cars are like mine (to a point), right?
Also, on a side note, is the Dark Grey-Green Metallic color the gun-metal-ish color? If not, do you, or anyone else for that matter, recall what that color is called? Thanks a bunch guysSteve
