It comes on if u get on it then when u stop and shut it off then back on it comes on and stays on for like 30mins but coolant is full anyone know why it would do this?
Low Coolant Light
Are you sure the coolant is full and you have followed the proper procedure to bleed all the air out of the system?Tracy
Well me and my dad put new themastat in it because when i was parked it would get about 230 degree. so my dad thought it was themastat so we put new one in then after we put new themastat in we had to put some more coolant in to top it off then light been coming on but it not done it for week but it kept coming on for like 2 weeks then it stoped1996 Firebird Formula
You must bleed the air out of the system after changing the thermostat. Here is how. http://shbox.com/1/4th_gen_tech2.html#radflush
BTW 230 is normal for the LT1 before the fans kick on.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Where are you checking the coolant level - in the radiator, or in the reservoir?Fred
If it persists and you know the radiator is full, it's the old classic coolant level sensor corrosion problem. 2 fixes. Buy a new sensor, which is only like $20 or $25. It's in the top right of the radiator, near the cap. Otherwise, pull the current one out and clean it off with emery cloth or 400 grit sandpaper. The problem is corrosion on it, which makes it not read the ground and set off the light. If the corrosion is gone, it works correctly. Mine was on for probably a year or more off and on, new sensor, no light."No, officer, that bottle is my onboard Halon system"
