What effects does removing the front sway bar have on the handling of the car.
Removing the Front Sway Bar?
A ton. Body roll like a 73 delta 98.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
I've heard that the handling is not completely destroyed, still possible to out corner the Delta 98 a bit
. I've also heard that it can help quite a bit with weight transfer off the line when draggin' by allowing more movement in the front suspension. Never tried it myself.
-- Flash
Flash - '97 Black WS/6, Intercooled Powerdyne 11#
**-** BOOST, it's no replacement for displacement, and there's definitely no replacement for having both!
