Allright Monsoon Experts....gm9-aux question
  • Allright Monsoon Experts....gm9-aux question
    Here's a toughy...
    I installed an gm9-aux input onto a monsoon system from a 2001 Blazer. The problem is that several lights are burnt out in the Blazer head unit. I have a replacement circuit card (where the lights are soldered in) from another Blazer Monsoon Head Unit, but it's one that doesn't support gm9-aux. If I swap out the circuit board, will that negate the gm9-aux compatibility?
    The only reason I ask is that it would be easier to swap the card than to re-solder the bulbs.
    Joe K.
    '11 BMW 328i
    '10 Matrix S AWD
    Well, it looks like the board is soldered in, so I won't be doing the swap. Instead I'll just be replacing the bulbs. I need to get a better soldering iron for more control though. The last time I did this with my $8 iron the results were iffy.
    Joe K.
    '11 BMW 328i
    '10 Matrix S AWD
      Make sure you get a DC Iron. You don't have to wory about magnetic fields destroying near by sillicon chips.
      Eric W.
      89 Firebird Formula WS6
      Accel/Lingenfelter Super Ram
      6.2L/382.97 ci
      Custom PROM Dyno tuned
      WCT-5 speed
      BW 9-bolt Posi 3.45
      Boss MS 18" Rims
      Custom Dual exhaust
      1LE upgrade
        Hmmm...I never thought about that. I'll look into it. Thanks!!
        Joe K.
        '11 BMW 328i
        '10 Matrix S AWD
          Its just that the AC versions make masive amounts of EM radiation with a big field area and can cause issues. The DC ones are EM free and usually work better too. Also when ever a person is done with the Iron make sure you put a good glob of solder on the end and let it cool, this will keep the end in tip top shape and wont oxidize during storage.
          Eric W.
          6.2L/382.97 ci
          WCT-5 speed
          BW 9-bolt Posi 3.45
          Boss MS 18" Rims
          Custom Dual exhaust
          1LE upgrade
