I'm looking into doing some mods on my 2k M6 Firehawk ... apart from fixing some minor technical problems (slight coolant leak somewhere around the water pump, grinding noise from the rear end, and it's NOT the wheel bearings, already replaced them) I'm looking at something like 400+ hp ...
As I will need to still be able to pass german inspection and emission testing, I can't go all out on this, nor do I want to sacrifice driveability and economy. Also, I do not plan on replacing the rear end with a 12 bolt or 9", so anything to extreme in the HP/torque area is also out of the question ...
I've had some advice and ideas from local F-Body folks, looking for some more detailed info on what to actually get ...
- Cam: One guy suggested the Z06 cam, as it's good HP for rather cheap $, and will keep the engine pretty much stock as far as noise and emissions go. Another suggested a mild, Thunder Racing cam, would need to look up the numbers he gave me.
- Headers: some long tubes, but with mostly stock clearing underneath - I have a PITA driveway, which I scrape the Camaro SFCs on if I don't watch out, so ground clearance is an issue. I know some el cheapo headers will go way down, while others will be just about the same depth as stock headers - any suggestions? Plus, what other parts will I need to hook them up to the stock Firehawk exhaust?
- Intake Manifold: Heard bad things about Fast, what about getting the Z06 manifold?
- MAF/Lid/etc.: I'm currently running w/o MAF being used (CLSD), with stock lid. Thinking about getting one of those dual cone air filters/intakes, and probably some bellow to replace the stock air intake tubing and MAF - any suggestions as to what make/parts to get?
Anything else I should upgrade with the motor while I'm at it?
As for the clutch, I figure it's starting to head south, with slight slippage at the track (I think), though street driving is still fine. What's a good aftermarket replacement? Got some cons on the Spec1, with recommendations again pointing towards a Z06 clutch assembly ...
Tnx!
Tnx!
