I put really inexpensive monroe shocks in the rear, and after 10k miles my car looks to sit lower in the back. I see other camaros that sit higher like my friends 98. Should I replace the shocks with stock ones to raise the rear up, it just looks like its way low. Thanks
Rear Sagging?
Rear Sagging?
Tags: None
The ride height is controlled by the springs, not the shocks.Fred
So could my springs be on the way out?1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
If they can't hold up the back end, they may be worn out. There's nothing else holding it up. There's a hard rubber seat between the top of the spring and the body, and they might possibly be worn, but I've never seen them fall apart. "Gas" shocks might exert a very small pressure in the upward direction, but not enough to make a visual difference in ride height.Fred
Yea I already replaced the bump stops a while ago. I'll look into getting a new set of stock springs. Is this a weekend project or should they be changed at a shop? Thanks for the help injuneer1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
You can knock out a job like this in no more than 1-4 hours alone- (depending on ur skill level). I replaced all 4 shocks and springs in about 3 hours (On a 1996 Z28). Alone. And that was with alot of breaks so its possible to do it in one day no problem.Originally posted by blackthunder50Yea I already replaced the bump stops a while ago. I'll look into getting a new set of stock springs. Is this a weekend project or should they be changed at a shop? Thanks for the help injuneerEddie
2000 M6 Trans Am
Tune+exhaust=344WHP
