here is my problem, i have a 91 firebird that had gotten stolen. i got it back within the first day but the main problem is that they broke the steering column in the car and tried to hot wire it. being it was a vats car they didn't get it running. the just drug it several block with a chain. i have replace the steering column and vats box. i figured that would fix the car but it didn't the car flashes the security light when you try to start it. if you check the codes it shows a nuber 46 which the book says is a vats failure. before i change the vats box i had a new key made to match the new steering column with the same key that the car used. the vats failure light flashed with the origanal box so i put in the box that came with the new column. same problem.
my question is does anybody have an idea of what to do to get the car back running? any help would be great. thanks Marty
