Well the motor is in the car and running.... sort of. The car is hard to start and won't start unless I play with the gas a little. It doesn't even pop really. Once it is started it runs fine. It idles low for a couple of seconds then it levels out just fine. The only codes in the computer are low coolant temperature. I think that is tripped because of the 160 degree stat. Do you have any ideas?
Mods include:
Pacesetter LT
3" exhaust
Moroso CAI
descreened maf
52mm ebay throttle body
LE stage 1 heads, cam, and intake
Ford 30# injectors
PCM for less tune
Rebuilt motor with about 11:1 compression
HELP!
Mods include:
Pacesetter LT
3" exhaust
Moroso CAI
descreened maf
Ford 30# injectors
PCM for less tune
HELP!
