last year i replaced my passenger side power window motor, because of the well known symptoms. ( window just stops halfway, after some minutes it will move again some inches etc etc).
Now at my drives side i've a different kind of problem. if i pull the window down, it will go just fine. but when pulling it back up, it went just about 2 inches. it won't go further up. going back down is no problem, but when pulling back up, only 2 inches. So i took the cross bar assembly out (being careful around the loaded spring, checked my rollers and gliders, greased everything, assembled everything again, same problem!
is it something i'm looking over? or is it just the power window motor again?
thanks for any input
