the problem is that the car starts fine and idles fine but as soon as you give it any pedal it dies. i thought it was the throttle position sensor but it took it in a had the sensor tested and it tested fine. so the question is does any one have an idea what might be wrong. i ran a codes check and it showed nothing. i also checked for a vacuum leak and couldn't find one. thanks Marty
problems with 91 firebird
Check Fuel Pressure and test the coil, Distributer and cap. There are many things on a third gen that can go wrong without throwing a code, especialy on the electronics side. Also a little info on the car would help alot. Eg. TPI/TBI/MPFI V8/V6 auto/std. mods etc.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Originally posted by DeWynterCheck Fuel Pressure and test the coil, Distributer and cap. There are many things on a third gen that can go wrong without throwing a code, especialy on the electronics side. Also a little info on the car would help alot. Eg. TPI/TBI/MPFI V8/V6 auto/std. mods etc.
i had an '89 formula that did the same thing. it wasn't multiport like yours. but it ended up being the fuel pump. i was dumb and didn't check fuel press. or volume and ended up spending alot more money than i needed to to track down the problem'95 T/A Conv., Green, Tan Top
'00 T/A Silver
'86 Chevy RCSB 4WD (LS1to go in)
