I got the 383 in tonight finally.I had a quick question regarding the oil pressure.The engine was broken in on a dyno before i got it so it was all ready and the oil pump was primed.The car started up on the third try.The oil pressure gauge showed zero pressure for about 3-5 seconds and the valve train was staring to get noisy.I turned the car off and restated,the oil pressure shot up to 60-70.The motor runs and sounds great and the oil pressure is strong now.My question is there any chance there may be some premature wear on the engine now.There had to be atleast a film of oil left from the break in and i had it topped off with oil too.Its not like i can do anything about it but i was just curious of what you guys thought.
oil pressure question
95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.Tags: None
Thats what i was thinking but i get kinda worried about stuff like that.I put about a hundred miles on it today and changed the oil just to check for any metal shavings.The used oil looked very good and there was virtually no shavings in it(thank god) there was a few tiny metal dust particles in it but nothing that you wouldnt see on any oil change.Thanks for the input.
