I'm in the middle of replacing a fog light bulb.
The last blew at some point. Apparently quite spectacularly as it was in two pieces. The fog light housing had some water in it that apparently caused this.
Anyway, I noticed a drain hole on the bottom of the housing. There's a circular adhesive piece stuck to it that's starting to come off.
Should I....glue it back in place? Or...remove it to allow some air into the housing to allow it to drain and dry out when needed?
