well my tires are wearing fast on the insides of both my front tires, but normally every where else. When i take my car to a tire place, what service should i ask for? Thanks guys.
tire tread question
It's the toe. If it were the camber it would be worn evenly but tapered across the tread.
http://www.ozebiz.com.au/racetech/theory/align.html2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Actually, if the front tires are wearing on the inside, that indicates excessive "negative" camber. In Lehman's terms, if the top of the tire is tilted toward the car it is negative, or if it is away from the car it is positive. A toe problem would give what is considered a "saw-tooth" effect across the tread.
Hope this helps.2001 Trans Am WS-6 A4
Slp Lid
K & N Filter
FTRA Kit
Corsa Cat-back
That's not true. Camber will leave an even taper across the tread. A toe problem will wear the first tread block on the inside or outside. Ask an alignment guy and they will tell you this.Originally posted by diamondjimtwoActually, if the front tires are wearing on the inside, that indicates excessive "negative" camber. In Lehman's terms, if the top of the tire is tilted toward the car it is negative, or if it is away from the car it is positive. A toe problem would give what is considered a "saw-tooth" effect across the tread.
Hope this helps.
http://www.goodyear.com/rv/tirecare/tirewear.html
"ALIGNMENT AND WEAR CHARACTERISTICS
Excessive Toe
Excessive toe-in/positive toe results in outside edge wear of the tire
Excessive toe-out/negative toe results in inside edge wear of the tire
Toe is easily adjusted on most vehicle steer axles
Excessive Camber
Excessive positive camber: smooth wear patterns on the outer half of the tire tread
Excessive negative camber: smooth wear patterns on the inner half of the tire tread
Excessive Scrub
Excessive scrub results in inside/outside steer axle tire wear patterns
Affects all tires on the vehicle "2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
its quite common with these cars...Originally posted by Mark BWhat does it mean when my back tires wear down alot faster than my fronts?
haha
dunno why
93 t/a A4 3.23s
99 Alfa Romeo 166 3.0 v6, red
97 3.8 v6 A4 camaro, hardtop
00 audi a6 4.2 40 valve v8
It means you should rotate the front to the back and proceed...Originally posted by Mark BWhat does it mean when my back tires wear down alot faster than my fronts?
haha
