I have the engine out of my 02 SS, and I am trying to decide which headers to go with. I want to install them now while motor is out. I also dont want to have to change them for a long time. I also was wondering if any tuning is needed after installation.
Headers
The SLP LT's really hang low... so low in fact sparks will been seen from your car. They have a great Idea behind them, just that in the end they are more of a headache to own than they a worth.
They header you get is really dependent upon how much $ you spend and what is more important in a header for you. Whether is be how well they fit or the price to keep the project cost low.
The kooks LT headers are the best fitting headers on the market for our cars. They are also stainless steel and quality built but pricy (I have these
- just do a search under my name and for headers for pics) . The pacesetter headers are quite popular as well. Hookers are cheaper, but some have complained about them.
In the end before you decide, make sure you know what your getting, as you'll be living with them for a long time. Maybe some other header owners can chime in as well and tell you how their headers are working for them so far
edit: link to my header install (with pics) . I agree with Joe (post down below) I think Kooks has a great headers but it's their custom y-pipe that gives the proper fit that is most noticeable.Rhode Island Red *Lurker since 1997*
pics and info
The main problem with long tubes is not the headers themselves, it's the Y pipes that usually scrape. A well made custom Y pipe should do better than most off the shelf items.
http://www.f-body.com/forum/showthre...ght=long+tubes
i have slp's and i love em. But my car is lowered, so the pasanger side hangs just low enough to catch speed bumps. If your planning on being low, id recommend something that tucks a little better. Like Joe said, usually is the y's, but on these headers that dang pass side just hangs a little low.
you can see here, that even with true duals, that one pass side spot hangs down just a enough to be a problem.99 Z Hugger Orange 9/05
93 Z 6/03
Zaino!!
I have Kooks LT's and can attest to their fit and finish. I had mine ceramic coated (2000º+), my headers never get more than 145ºF.
2001 SOM Camaro SS. 1SD options, Neutral leather, ASR, 6spd. H/C, exhaust/intake/suspension. Full list of mods here:http://img.photobucket.com/albums/v3...atasheetSS.jpg
Just curious, what's the condition of the motor mounts? The only reason I ask that is that I see two owners that both say the headers scrape and it suprises me that SLP would have it engineered that way.Originally posted by xxRillixxi have slp's and i love em. But my car is lowered, so the pasanger side hangs just low enough to catch speed bumps. If your planning on being low, id recommend something that tucks a little better. Like Joe said, usually is the y's, but on these headers that dang pass side just hangs a little low.
I just thought I would add a point to the fray. The possibility that shorties or mid lengths would be more beneficial. I've seen quite a few cases where cars with shorties dyno'ed within a few HP of long tubes provided the rest of the system it top notch. The purpose long tubes is boost low end torque, many even lengthen the collector to optimize torque below the peak. That's really helpful in automatic trans cars. In short, shorties rock at high rpm with a good Y pipe and cat back. There are also no worries about scrapes even on lowered cars, that's probably the best benefit right there.
The motor mounts are fine, the car has like 60k miles on it.... Im pretty sure if it was stock height, it would be ok. But with those and lowering its just enough to catch speed bumps. I havent had problems like the person above saying they have seen sparks... i think ive only had it scrape once on the road (not speed bumps).Originally posted by Joe 1320Just curious, what's the condition of the motor mounts? The only reason I ask that is that I see two owners that both say the headers scrape and it suprises me that SLP would have it engineered that way.99 Z Hugger Orange 9/05
93 Z 6/03
Zaino!!
