Problem: Car cranks for 4-7 seconds before firing. Sometimes sounds like it backfires in the manifold while doing so.
New discovery: Cracking the throttle even the slightest (as little as you can with your foot) makes it start like brand new, hot or cold. I am assuming this is letting a little air past the slightly open throttle blades. Are there any passages in the TB that might be blocked? Other suggestions? Besides holding the gas a little when starting
Fuel pressure checks went well yesterday and everything seems to be in spec. 32+ when key moved to on. Same with vacuum at idle. 42 when vacuum removed. Question is how quickly should the pressure bleed off after the car is shut down. Mine goes from 30+ to about 20 in the first 10-15 mintues. After that it goes down slower. What is the normal rate, if any?
BTW replaced EGR yesterday. I didn't think it was a problem solver, but I knew it was frozen. Got it out and it sounds like it is full of sand and rocks.
Thanks again!
Sean
Thanks again!
Sean
It would be advisable to use 02 sensor safe TB cleaner.
