So this is the closest thing I have to a track where I live and these are the numbers my car put up. It ran a 14.2 @ 101 mph with a 2.65 60 ft time. (elevation 4385 ft) Peak HP was 326. Are these good numbers considering the elevation. And I am assuming the HP is RWHP because the computer takes into account the drive train loss and drag coefficient.
Beltronics Vector 2 results
1999 Ram Air Trans Am. M6
Its a cool toy! I've driven my car alot harder since I've gotten it though. There isn't a good track with 150 miles of where I live so, for me, its a great investment. I found some conversion factors for elevation and this is the equivalent to a 13.4 @ 105 mph. If I work on my 60ft times my trap times should be much better. The road I did this on was not the best for traction.Originally posted by ConEliteThat seems about right. The weird thing is the 2.6 60 foot. Running a 14.2 with a 101 trap speed. Thats pretty good though. So how do you like it? Is it worth it?1999 Ram Air Trans Am. M6
The NHRA altitude correction factors for 4,385-ft are:
ET: 0.946 X 14.2 = 13.43
MPH: 1.0575 X 101 = 106.8 MPH
The MPH would be indicative of a healthy, near stock LS1. The ET isn't that bad, and considering the weak 2.65 60-ft time would indicate the car should be easilly capable of breaking into the 12's at sea level. Simply be getting the 60-ft down to a decent 2.0 would put you in the low 13's at 4,385-ft.
If the Vector 2 is similar in accuracy to the original g-Tech, your ET is probably withing 1/10th of what you would see at the track, while the MPH could be anywhere from 2 to 4 MPH better than you would see.Fred
I've got one of those original G-Techs sitting around here somewhere. Got it free when I bought a set of BFG tires about 5 years ago, and I think I used it once. Maybe I'll have to bust it out and start playing with it again.95 Z28 - K&N FIPK, Flowmaster cat-back, Edelbrock STB, UMI Perf SFC, Performabuilt Pro Street 4L60E, 2800 Stall, Hayden tranny cooler, CRT Intake elbow, LS1 DS, 2k C5 replicas, Toyo Proxes T1S 255/40/17(f) 285/40/18(r), slotted rotors w/ Axxis MM pads, 15% front/5% rear tint, 97+ Console upgrade, all oils now synthetic
Bought and
to install: UMI Adj LCA, Adj Panhard, LCA relocation brackets, 96 SS Spoiler....Broken and
to be fixed
I ran my car again this morning and I got a 14.1 @ 97 mph (rabbit in the way)
. 2.15 60ft time though
. So it gave me A rwhp rating of 343 @ 78mph. I have my cars weight entered @ 3820 (I weighed it at work on the truck scales), I entered the drag coefficient at 6.72, and my manual transmission drive train loss @ .15. Does this sound correct.
Originally posted by Joe 1320Doesn't sound correct to me. Most cars have a CD of .30 to .60 so I'm not sure where you are pulling your number from. I haven't messed with CD figures in years so maybe I'm missing something?
My bad I am mixed up, I have that number set at .35. There is another number the represnts the area of the front of your car. the default is 7 a c5 corvette is a 6.5 so I set mine at 6.72.1999 Ram Air Trans Am. M6
