Whats the gear ratio in the rear for an automatic 2000 trans am. I thought it was 3.43 but im not sure.
Rear gear ratio
Rear gear ratio
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
I am wanting to think 3.23's1999 Ram Air Trans Am. M6
and i jst went on the higway and recorded my speads at 50, 60, 65, 70, 75, 85, 90, 105 in third gear and im coming up with a rear gear of 2.7-2.8.... does anyone know the right number.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
Originally posted by Dragkid1917and i jst went on the higway and recorded my speads at 50, 60, 65, 70, 75, 85, 90, 105 in third gear and im coming up with a rear gear of 2.7-2.8.... does anyone know the right number.1999 Ram Air Trans Am. M6
i know for a fact the M6 and the A4 are different, i did alot of tests and when i raced i shifted gears right be4 the end of the track at about 98 mph, and it came throo at 104 mph, witch means the 3rd gear rpms are way too low and not really pulling. I went 105 in third today and i was at a low 3900 rpm. all my tests point to a 2.73 rear, if i had 343's at 105 id be at about 4700 rpm, using 245/50/16's (80.375 circumfrence which i measured like 4 times). Im gunna put small tires on to get a few more rpm's in third gear for when i race. I wanna do this cuz if i have to lift against someone, i dont want it to shift down on me, or not have enough power to actually pedal my car without them getting by me.
When i went a 13.47, there was a bit of a tail wind, but i still used 245/50/16's that were almost completley bald, and i did a pretty big burnout, they were kindof like slicks, and my best 60 ft was a 2.04[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
Originally posted by Dragkid1917When i went a 13.47, there was a bit of a tail wind, but i still used 245/50/16's that were almost completley bald, and i did a pretty big burnout, they were kindof like slicks, and my best 60 ft was a 2.04Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
Stock GM put a lot of 2.73 axles out there (probably to give a higher Corporate Average Fuel Economy, CAFE number). The performance option was a 3.23 for the A4, and the M6 came with a 3.42. Check your build codes on the door, a GU2 was 2.73 axle, GU5 was for 3.23, and GU6 indicates a 3.42. G80 is the RPO code for positraction-2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
The "base" V8 A4's came with 2.73 (GU2, 2-series carrier) gears. If your car was ordered from the factory with the "performance axle package", it had 3.23:1 rear gears (GU5, 3-series carrier). ALL 94-02 M6's are 3.42:1 (GU6, 3-series carrier). The 93 M6's are the only non-3.42 M6 cars, with either the 2.73 or 3.23 rear axle ratios as well (and steeper 1st gear ratios in the T56).
Typically (but not always), if the console does not allow you to select "1" and you have the 110+MPH speedo, you will have the 2.73 gears. If you can select "1" with the shifter, and you have the 150+ MPH speedo, you will probably have 3.23's.Fred
