Well over the past 2 or 3 weeks I have been noticing that it seems like the clutch is going out (Replaced it 2-3 months ago). When I begin to drive every morning to work, Im driving normal and everything is fine. First gear grabs real hard, no problems. I put it into second, nothing, and if Im like in 3rd, 4th, 5th, or 6th and I push in the gas to simply speed up a little quicker than normal and the engine rev's up like its slipping like crazy then i let off and it grabs again. Im guessing that its the clutch, but I just replaced it. The rear main seal was not leaking and Im not leaking any oil from what I know. It would make sense if it was leaking oil and it got all over the Clutch, but its not leaking at all. I did not replace the Slave when I did the clutch. Im pretty sure its the Original one (61k miles). Can it be that the Slave is not disengaging completely? Has anyone ever hear of this? I want to see if maybe there is something im overlooking before I spend another f%$#en $400 on another clutch
. Its a SPEC S1. I heard good things and bad about these clutches. If I replace it Im going with a stock one and a new Slave.
