O2 sensor extension
  • O2 sensor extension
    Hey guys. I have to extend the o2 wires on my 93z. Is it okay to extend the wire at the sensor rather than cutting the main feed and extending it. I read something about this before but searched without any luck. So sorry if i'm beating a dead horse.
    hey i had to go through the same thing...on thunderracing.com they have o2 extensions...they run for about $22 each. that should do the trick
    1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
      Yeah i'm in a jam though. I need to get this done asap so i can get inspected before my IM sticker runs out. Or i have to go through the whole testing process. So i need to do a temp. splice.
        Do not cut the wire on your 1993 single-wire O2 sensors (all later year engines use 4-wire heated sensors). Cut ONLY the harness wire. Solder the connections.
        You may have to convert to 3-wire or 4-wire heated O2 sensors if relocating the sensors farther away from the engine causes them not to heat up enough to function correctly.
