What would I have to change to put a 12 inch rotor on a 1995 Trans am. I am pretty sure it has stock 11 inch rotors and i am hoping to use parts off of my uncles 99 camaro to put some 12 inch cross drilled and slotted rotors? Any help would be great
Brake conversion to fit 12 inch rotor?
If you are talking about putting LS1 brakes on your LT1 it's not hard. Here is a picture I took when I did mine. LT1 left LS1 right
http://www.claire-marie.net/LT1vsLS1_brakes.JPG
The parts you see is what you will need except the brake lines will not mount to the bracket on the frame. You can either drill out the brackets so the LS1 hoses will mount or you can get a set of Earls stainless steel lines. It's worth the upgrade too. You will also need a front end alignment when you are done. You will need a ball joint and tie rod splitter. I used a 2 prong gear puller.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
The knuckle (big bracket) is different. Look at the picture. You also have to use the brake hoses for the caliper you are putting on.Originally posted by chromedfeetAs far as the backend goes, I would just have to change the calipers to fit on the larger rotor, right?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Jeff 95 Z28,
I am also in the process of doing the LS1 brake conversion. I have ordered parts from Tenessee Auto and am about to order rotors, pads and lines.
On the subject of Earl's Stainless lines I will need to get a kit designed for an LS1 like this one correct?
Are the lines for the rear the same for LT1 and LS1 vehicles?
Do I need anything special since I have TC?
Thanks.My DD
2015 Lexus GS350 FSport
My toy
Correct. You get 5 lines with the kit. 4 for each caliper and the one that goes from the pumpkin to the frame.Originally posted by sneitzelJeff 95 Z28,
Another source http://www.stealthperf.com/cgi-bin/store/28A460.html
To be honest I don't know. I replaced the whole rear axle in mine at the time so I never even unbolted the lines from the caliper. I used the single hose that goes from the axle to the frame near the pumpkin that was on the LS1 axle. One day I'll actually put on the Earl lines on the rear.Originally posted by sneitzelAre the lines for the rear the same for LT1 and LS1 vehicles?
I don't have TC so I don't know.Originally posted by sneitzelDo I need anything special since I have TC?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
One more thing about using SS lines. They don't expand when you press on the brake pedal. They make for a very firm pedal. Be careful when you get in to drive a car without them. The pedal will travel further before the brakes start slowing you down. Then you get used to it and get back in your car with them and you almost throw yourself through the windshield. I think I am going to put some one my wife's PT Cruiser.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
no. Just hook up the cable.Originally posted by chromedfeetWill i need to replace the emergency brake on the backend when i swap the calipers and lines2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
