Well As you know I had the problem with my tires. That's pretty much gone. Now After I got my car aligned I noticed that the car still pulled to the left like is had ever since I lowered my car. The guy adjusted the thrust angle b/c I had it all wrong when I installed my Adjustable control arms. So at this point the steering wheel is straight but the guy said that the Camber is off a bit in the front. He claimed that he didn't want to adjust it b/c the bolts on the lower control arm are on there with lock tight and if he loosens them the chances of them staying tight are slim. (I think that's not right) I'm going to see if it gets better. I cant stand the fact of having to keep constant pressure to the right in order to keep the car from pulling to the left. its very very light. Does anyone else experience this?
Thanks a lot guys.
Thanks a lot guys.
adjustable and this and that. Well I called Some other shop asking exactly what they would adjust on my car, and the guy knew right away b/c his brother has an f-body. He said the Thrust angle, The Front Camber, Caster and Toe all for only $10 more than what I had already paid. At that point I was mad, but the guy started working on it. He adjusted the Caster, Camber and toe to the best possible specs he could. The Camber was still a bit off but it was within spec. Ill give you guys the eact numbers later on tonight. I took a picture of the screen b/c I felt he would not wanna give me the print out (Which he didnt). The thing ride straight. no pull so far so we'll see how she acts tomorrow on the freeway.
