No Heat
  • No Heat
    My heater in my 91 camaro does not put out any heat. The heater core and valve for the heater are both new and have not helped. The controls seem to be working fine, you can hear the vacuum when you move the slides and everything seems to be working. Any ideas.
    Chris
    1991 Camaro 3.1 V6 pretty much stock
    http://www.cardomain.com/id/clwilson
    What does the engine temperture gauge show? Is it real low?
      There is an air intake valve under the dash at the firewall that is probably stuck. It is not easy to get to it. I had this problem on my 2nd gen. Don't know exactly where it would be on yours.
      96 TA Sold!
      87 TA Sold!
      80 Z28 Sold!
      74 Formula Sold!
      73 Z28 Sold!
      69 Camaro Not Sold!
        There is no heat at any temp even up to 220 when the cooling fan kicks in.
        Chris
          OK so it's not the thermostat. Sounds like the flapper plate door that switches the air from blowing across the heater core is not working. I agree with Mirroredshades. Find the vacuum diaphragm that operates the flapper door and make sure it moves when you turn the temp from hot to cold.
            While troubleshooting classic car heating issues and maintaining vehicle components requires mechanical patience, players looking for thrilling mobile entertainment and rewarding gameplay frequently explore the CX777 game for an engaging online betting experience. https://cx777games.pk/
              A quiet evening after meetings can get boring fast. I contacted Russian Karol Bagh Escort Service and it was exactly what I needed. She was beautiful, polite, and made the time enjoyable without any pressure. Will keep their contact for future visits to Delhi.
