Ive heard very different things involving cam swaps, from someone whoos experienced, just how easy/ what do you need to dissasemble. Im not asking how to do it but am i going to have to pull the motor out cuz theres not enough room or is this not such a bad change.
cam swap
cam swap
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
Look in the "How To's" section of my Tech Page. There is info on how to remove and install a cam.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
that awsome man, thats a huge help, having said that, what would be the best cam for my basically stock ls1, (Crane cams 1500-6000 216/224 .551/.551) (trick flow 2,000-6000 2.16/220 .560/.560) or ( comp extreme 1,800-6,000 222/224 .566/.568) Now im not just talking about the power, but the compatibility to my basically stock engine, if i can use the extreme cam, witch seems to be the best, then i would go for it, im just not sure if its too much, or what other parts that would require me to get.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
do you want a cam that's going to work with the stock computer chip or are you going to have the car tuned once you do the cam swap?
of those cams you listed will work with the stock computer tune.
87 GTA: it's winter time, all tore apart
my frend has a power tuner, so I can tune it using that[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
a little help?... please?[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
look into custom grinds. If you're going to put a cam in, you may want to port the heads and put new valvetrain in. You're also going to need headers on there.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Your better off getting a custom tune. And As Raro Said your going to need headers and Recommend some Rockers, Push-rods and Springs. That will give you a nice number. Thats my plan when I do my cam Swap:Originally posted by Dragkid1917my frend has a power tuner, so I can tune it using that
Roller rockers
Valve Springs
Push-Rods
Lifters
Custom grind Cam
Custom Tune
Mid-Headers
ORY-Pipe
LS6 Intake Manifold
(No head work)
Should put me in the high 300 to low 400 hp range Im hoping. Pushing me mid to low 12's before I blow my rear-end. ha ha ha haEddie
2000 M6 Trans Am
Tune+exhaust=344WHP
well im running on a serious budget, cuz soon im going to be pouring my money into a real racecar. that cam that i said should fit in with the stock stuff, and yes, headers and a full exaust are on the way. If i had the money, i wouldnt even be using the stock heads at all. And when you say custom tune, cant you custom tune stuff with a power tuner?[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
somewhat yes, but not to the full extent of an actual dyno tune.Originally posted by Dragkid1917well im running on a serious budget, cuz soon im going to be pouring my money into a real racecar. that cam that i said should fit in with the stock stuff, and yes, headers and a full exaust are on the way. If i had the money, i wouldnt even be using the stock heads at all. And when you say custom tune, cant you custom tune stuff with a power tuner?87 GTA: it's winter time, all tore apart
how many miles does your car have? if you're under 100k adding new pushrods and lifters is just a waste of money.Originally posted by ConEliteYour better off getting a custom tune. And As Raro Said your going to need headers and Recommend some Rockers, Push-rods and Springs. That will give you a nice number. Thats my plan when I do my cam Swap:
Roller rockers
Valve Springs
Push-Rods
Lifters
Custom grind Cam
Custom Tune
Mid-Headers
ORY-Pipe
LS6 Intake Manifold
(No head work)
Should put me in the high 300 to low 400 hp range Im hoping. Pushing me mid to low 12's before I blow my rear-end. ha ha ha ha87 GTA: it's winter time, all tore apart
Sorry, I did not notice you had an LS1, so my cam guide is not for you.Originally posted by Dragkid1917that awsome man, thats a huge help, having said that, what would be the best cam for my basically stock ls1, (Crane cams 1500-6000 216/224 .551/.551) (trick flow 2,000-6000 2.16/220 .560/.560) or ( comp extreme 1,800-6,000 222/224 .566/.568) Now im not just talking about the power, but the compatibility to my basically stock engine, if i can use the extreme cam, witch seems to be the best, then i would go for it, im just not sure if its too much, or what other parts that would require me to get.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
shiza, ok anyone with an LS1 for the cam install help, at the track today i noticed everyone launched so much harder but i pulled on them hard at the end i was over 105 mph, i dont wanna change the gear cuz my reaction times are good where they are now, i just wanto be able to go like 112-114 mph and ill be totally set, i think a cam and full exaust will do it.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
