This may be a dumb question, but on the LT1 engine, does coolent flow through the intake? In other words, can a blown intake gasket leak coolent into the combustion chamber? (an only the combustion chamber; no external leaks)?
Coolent through the intake?
Originally posted by 88bird5spdu can pull the heads off with the manifolds attached, just disconnect them where they meet the y pipeReally?! Wow, I think that just made this job half as bad! I never would have thought you could do that. Thank you for the tip!
'96 Firebird Formula, LT1, stock, automatic
Originally posted by brothapig... In other words, can a blown intake gasket leak coolent into the combustion chamber? (an only the combustion chamber; no external leaks)?Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Originally posted by Rob B (shoebox)Yes, it can.Tracy
Update
Well, I guess it's time for an update
I did not have any external coolent leaks - until I pulled it into the shop yesterday. Turns out it was the water pump the whole time. Bearings were completely out. Got that done in a day, then changed oil and trans fluid.
So far so good. Thanks for everyone's help and suggestions during the time I thought it was a head gasket.'96 Firebird Formula, LT1, stock, automatic
no coolant goes through the intake just the throtle body but i dont know how it would get through there. unless the coolant is in the oil and coming up through the pcv.forged 383 LT1,11.5:1 compression,main girdle,custom comp cam,1.6 pro magnum rocker arms,ported heads,hooker supercomps,3"true duals,52mm throttle body,accel 300+ ignition,centerforce dfx clutch,B&M shifter,soon a 175 shot.
