I have an LT1 '89 Firebird w/ an electronic speedo. I'm putting a TH350 in it shortly. The only way I have found is to use a "VSS VDO Sender Dead End" from Caspers Electronics and route it through a "Universal Signal Interface" from Dakota Digital. Also, build a resistor box I found on fbody.com. (link at bottom) Do you think this will work? I want to be sure before I get into all that. Thanks_LT1_Performance
VSS VDO Sender- $90.00
Universal Signal Interface- $75.00
Resistor Box (build cost)- ~30.00
http://www.fbody.com/tech/details.cgi?id=18
