I was just out driving and I let off the gas and it stayed at 2000 RPM, then crept up to 2500. I then put it into neutral and it shot up to 4500. It did it real quick, almost like I was revving the engine at a line of hot women. So what's going on?
Strange Reving
take a look at your throttle body and hit it with some throttle body cleaner and a paper towel. make sure to hit in between the butterfly valves too, that's your idle.
and check your vac hose that connects to the intake-Ryan-
I haven't had the problem since that one incident. Although the mat getting jammed with the accelerator sounds like a very plausible theory, it just doesn't fit what happened (can't really explain it). I just cleaned out the TB two weeks ago and the IAC seems to be working just fine idling at about 800 at a stop. I'll post if this happens again.
2002 Firehawk Sold
