I bought a '95 Formula Firebird convertible about a year ago as a project car and taken care of the usual leaks, overheating, squeeks, slow windows, slow convertible top, etc. without much help. Getting down to the last few real problems, I'm having trouble finding documentation to help. So here's one I hope the forum can help with.
The transmission wiring for some reason has been relocated over the top of the engine wiring harness (ECM wiring) and over the passenger side valve cover and down to the tranny over the top. I pretty sure that it's not right, and not sure why it was moved. It's WAY too tight, and it's going to eventually break if not moved. Does anyone know the proper wire harness path? Pictures? Which Manual?
I suspect it was moved when the new catalytic converter was installed before I bought the car. It's a factory GM cat setup, so the wiring harness should fit in the stock location.
Thanks for the help,
Jim
Jim
